Topic: Centering crossfader on initializing
KronsterControlleristMember since 2010
I don't mix with a crossfader and I would just bump into it constantly so I removed it, but now when the mixer starts up.. its all the way left. Once I center it using the software... it stays that way and everything is fine. Is there a way to have it center when I initialize it? For now I just programmed a button to do it:
SHIFT_FLIP_SLOT - crossfader 50%
Any help would be great. Thanks!
geposted Sat 18 Dec 21 @ 1:36 am
add your script to the keyboard oninit key, that's the place for start up scripts
[ONInitialization] or you could disable the crossfader in the settings.
geposted Sat 18 Dec 21 @ 1:41 am
thanks.. I'll give that a try. Still trying to get the blink working.. I put that in another post!
geposted Sat 18 Dec 21 @ 3:33 am
