Topic: No sound
LarchyPRO InfinityMember since 2018
My god, there's no direct support.
I now for the 3rd time have had the app stop playing the music on eithe rone of the sides.
Is there a fix for this?
Chris
geposted Sat 18 Dec 21 @ 3:12 am
If you provide some more info, then probably yes.
geposted Sat 18 Dec 21 @ 6:07 pm
following> I had exactly the same thing happen. Did you upgrade to new version? I did and it played again butno idea why it stopped in the first place. My sound settings appear to be fine (worked before and after)
geposted Sun 19 Dec 21 @ 2:06 pm
