Topic: Gemini CDMP 7000 Controller
I'm looking to get a Used Gemini CDMP 7000 like new, was only used about 3 times, question I have was doing some reviews and on YouTube, heard that the mixer part won't control your software, only the decks will, Phil said in the video that your software with have to be set in External Mode, So If I'm using Virtudal Dj, Will it work then doing that,,Need some help here and answers before I buy the Controller from the other person,
geposted Sun 19 Dec 21 @ 9:59 pm
I would suggest to look for something more recent with full Midi control.
Possible issues..
- Too old model and could have some compatibility issues with new OS (windows or mac).
- The mixer part of the device is not Midi, so it wont control the VDJ mixer, which means that you wont be able to use Stems with EQ.
geposted Mon 20 Dec 21 @ 8:09 am
