A while back VDJ had the feature where you could right click on the individual mapping, and make each controller independent (as per this post https://www.virtualdj.com/forums/229486/VirtualDJ_Technical_Support/DDJ_1000_and_DDJ_XP1_at_the_same_time.html?search=Xp1&page=1 )
It doesn't work like this anymore and my XP1 is messing with the RZX screens. Is there an easy way to make them independent again how it was before. Thanks
geposted Mon 20 Dec 21 @ 2:23 pm
http://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html#controller
Have you tried to use the GUI to assign pages ?
Mind you that if you use custom mappings made before the 2021 release the above procedure won't work.
In that case let us know so that we can tell you what extra changes you need to make on your custom mappers to make it work.
geposted Mon 20 Dec 21 @ 11:39 pm
Yes, I think my mappings go back to the early version for the RZX as I made all the redundant buttons at the time do other things, although I did copy over from the latest mapping a few things to get the central screens to have the search function. If its not too much trouble to get the info I need to change, that would be great.
geposted Tue 21 Dec 21 @ 7:17 am
You need to go over PAD_MODE buttons and their leds and use the following actions instead of the old ones
Same rule goes XP1 as well.
<map value="PAD_MODE_HOTCUE" action="pad_pages 1" />
<map value="PAD_MODE_PADFX1" action="pad_pages 2" />
<map value="PAD_MODE_SLICER" action="pad_pages 3" />
<map value="PAD_MODE_SAMPLER" action="pad_pages 4" />
<map value="PAD_MODE_BEATJUMP" action="pad_pages 5" />
<map value="PAD_MODE_PADFX2" action="pad_pages 6" />
<map value="PAD_MODE_SLICER_LOOP" action="pad_pages 7" />
<map value="PAD_MODE_SAMPLER_VEL" action="pad_pages 8" />
<map value="LED_PAD_MODE_HOTCUE" action="pad_pages 1" />
<map value="LED_PAD_MODE_PADFX1" action="pad_pages 2" />
<map value="LED_PAD_MODE_SLICER" action="pad_pages 3" />
<map value="LED_PAD_MODE_SAMPLER" action="pad_pages 4" />
<map value="LED_PAD_MODE_BEATJUMP" action="pad_pages 5" />
<map value="LED_PAD_MODE_PADFX2" action="pad_pages 6" />
<map value="LED_PAD_MODE_SLICER_LOOP" action="pad_pages 7" />
<map value="LED_PAD_MODE_SAMPLER_VEL" action="pad_pages 8" />
geposted Tue 21 Dec 21 @ 7:54 am
Thank you. Will update it now =}
geposted Tue 21 Dec 21 @ 7:59 am
