Topic: Microphone glitchy USB
Windows 10 Pro version 21H2 (19044.1415)
VDJ: 8.5-64 b6781 (but applies to all versions in the last year and beyond)
Microphone: Audio-Technica AT2020 USB+ and Audio-Technica Cardioid (AT4033A) using USB interface
CPU: 3900x & 5950x, GPU: 1080ti & RTX 3090 (tested on two different computers)
Problem: When using cueing the microphone on sometimes it starts to glitch and get a lot of interference like it's getting a bad signal. The only solution to this is to reset the usb interface physically by unplugging it and re-plugin it back in. This does NOT happen in other software where it uses a line in microphone (Traktor, Serato, RB), or any other software that utilizes it, like Discord for example.
There is no difference when changing the microphone quality settings or setting exclusive control of the devices.
I had another thread about this but it was deleted (moderator deleted?) with no responses.
Issue has been present almost entire time I've been using the software.
geposted Tue 21 Dec 21 @ 12:00 am
This is still unresolved.
geposted Mon 21 Feb 22 @ 5:11 am
