Topic: Channel Fader Reversed
Hi all, i have recently purchased a Numark M2 mixer and connected everythign up. However the channel fader levels are flipped. Channel 1 controls deck 2 and channel 2 controls deck 1, any ideas how to get these back to normal?
Also, i understand I cant control the bass/mid/treble from the mixer this still needs to be done in VDJ, is that correct?
Im pretty new to this so any help will be appreciated.
Im running VDJ on a pc, output through headphone socket to splitter then into mixer.
Thanks, Tin.
geposted Tue 28 Dec 21 @ 9:08 pm
geposted Wed 29 Dec 21 @ 12:47 pm
Thanks for the info, my setup is the same as this - https://www.youtube.com/watch?v=xImxf8Js-YI
Everything is working including the channel EQ's which i though wouldnt work, however the channels are reversed so wasnt sure if thats some mapping issue?
geposted Wed 29 Dec 21 @ 1:14 pm
So the reversed channel issue was resolved by swapping cables in the back... cant believe it took me so long to figure that out!!
However, could anyone recommend / suggest an external usb soundcard that will work with my setup please?
Thanks,
geposted Thu 30 Dec 21 @ 4:06 pm
