Topic: Key command to show vst effect gui
MC242PRO InfinityMember since 2017
Hallo, I haven't found a solution to this so far, so I have to ask here.
Working with a vst effect, sometimes the vst effect gui disappears behind the Virtual DJ gui. When I want to show it again I always have to go into the effect list and find that tiny wheel on the right side of the effect name and press it.
That's a lot of hassle in a live set.
So I would like to know if it's possible to map this gui to a keyboard command and how this keyboard command would look like, please.
BTW, I'm using a vst effect on the master effect deck.
Thank you!
geposted Wed 29 Dec 21 @ 4:21 am
deck master effect_show_gui 'MyCoolVSTEffectName'
geposted Wed 29 Dec 21 @ 8:19 am
Working straight away, even without the plugin or effect name.
Thank you so much! I love this forum!
How did you know the command?
I couldn't find it in the commands list in the manual.
geposted Wed 29 Dec 21 @ 8:40 pm
geposted Wed 29 Dec 21 @ 8:48 pm
Thank you very much for the link/list! This is awesome! VDJ is incredibly versatile!
Yes, I recognized that the gui of the currently inserted effect/plugin is pulled up, which is exactly what I wanted. :)
geposted Thu 30 Dec 21 @ 12:35 am
