Hi I am using a Gemini PMX-10 and when I use PFL 1 and PFL 2 with Virtual DJ, PFL is silent when I turn my faders down. I know it's the program because it works with regular records. Without Virtual DJ I can hear either track when the fader is turned down but not when I'm using virtual DJ.
geposted Wed 29 Dec 21 @ 6:54 am
It works when i switch between Hardware, DVS and Software mode but not when i save the settings. It seems when i have my timecode vinyl on in settings that it doesnt work too.
geposted Wed 29 Dec 21 @ 9:53 am
Something is wrong in your Audio setup then. Please see here how it should be in each mode .. https://www.virtualdj.com/manuals/hardware/gemini/pmx10/advanced.html
As per manual ...
"Each time a mode selection is performed, VirtualDJ will ask you to apply the necessary Audio setup for the selected mode"
Is this the case ?
As per manual ...
Is this the case ?
geposted Wed 29 Dec 21 @ 12:16 pm
As per manual ...
Is this the case ?
As per manual ...
Is this the case ?
Yeah ive been doing separate decks in software mode because there was something wrong with the 1st deck going quiet when i use the crossfader and using PFL makes the master volume louder
geposted Wed 29 Dec 21 @ 12:55 pm
