Hi,
After an export, most songs show the waveform at the bottom of the screen but some don't. All the tracks play fine. I have the latest firmware for the CDJ and have reformatted the USB device a few times but some tracks still don't load the bottom waveform. Also, in the "CDJ Options", changing the "Waveform Color" setting to "RGB" has no effect on the waveform color. There used to be a setting to choose which CDJ you are using. Is this a factor?
geposted Mon 03 Jan 22 @ 2:52 am
