Hi, I've just set up DVS in the latest Virtual DJ and wanted to know if it looks ok to you.
My setup is:
Macbook pro (intel) running Big Sur
Allen and Heath 23C Mixer
2 x Technics SL1200
Ortofon Mix Mk2 cartidges and needles
Here is a video showing the timecode signal: https://imgur.com/a/ONlPFnj
You'll notice they both seem to jump around/vibrate quite a lot, is this normal or does it indicate an issu with my setup?
Thanks!
My setup is:
2 x Technics SL1200
Thanks!
geposted Mon 03 Jan 22 @ 3:30 pm
Just to add to this, I am trialling Virtual DJ in the restricted 10 minute demo mode to see if it's a suitable option to pay for, but before doing so I want to make sure my setup is working as it should be. As far as being able to mix the tracks it seems to be functioning normally except a bit of continuous pitch drift, so I'm wondering whether the signal as shown in my video is indicative of an underlying issue somewhere in my hardware/software setup or it is supposed to look like that.
Thanks for any help
Thanks for any help
geposted Tue 04 Jan 22 @ 8:07 am
