Topic: Virtual folders still unreliable
Don't you just love software that deletes your work? Virtual folders are not "safe" in VDJ. Especially newly created ones tend to simply disappear once you click the expand icon. The phenomenon seems to happen at random. I've tried backing up the database, but it doesn't seem to help in any way. Would be really nice if this was fixed or at least if someone can teach me a workaround.
geposted Tue 04 Jan 22 @ 12:08 pm
Do you use Windows or MAC ?
Any external drives connected ?
Where do you create your Virtual Folders ?
I never had any issues with them, especially if you understand how they get stored, which is "virtually anywhere" you choose to create them.
In other words, it is of important significance where you are browsing the moment you hit the "New Virtual Folder" button.
geposted Tue 04 Jan 22 @ 12:19 pm
