I just noticed that in the most recent Earlier Access build BUILD 6794 that the Stop button in the Automix Editor is not working properly. If you are listening to the Editor and you click the Stop button, the audio stops but the position and the time counter continue to progress. Clicking the Stop button again changes nothing and it seems that the Auto Mix Editor needs to be opened and close in order to get it to work again.
I re-installed the current release BUILD 6747 and issue mentioned above does not occur.
Thanks
Thanks
geposted Sun 09 Jan 22 @ 6:17 pm
I can confirm that this issue does not occur in Earlier Access Build 6781
geposted Mon 10 Jan 22 @ 4:47 pm
Should be fixed in 6800
geposted Tue 11 Jan 22 @ 4:32 pm
I can confirm that the problem is fixed in 6800. Thanks
geposted Tue 11 Jan 22 @ 8:47 pm
