I am using VDJ v8.5 B6800 and I do not see 'waveforrms' in the browser column (under Waveform).
I am using a Skin [DennYo] but even with the Default skin,
I do not see 'waveforms' for each individual song, inside browser column,
and it has been like this for me, for last 2 or 3 builds.
How to remedy this ?
geposted Thu 13 Jan 22 @ 9:20 am
You need to load the track on a deck first, or rescan the file for BPM e.t.c.
Once you do this, VirtualDJ will create the waveform graphics and will store them inside a special file in order to use later.
Keep in mind that currently unless you browse to a different folder with a lot of files and back (in order to refresh browser cache) the waveforms won't appear immediately after loading or scanning them.
This will get improved on a future update.
PS: VirtualDJ was already creating the waveform preview graphics for quite some time now, but this mechanism was part of the experimentalBeatAnalyzer.
It has now moved to the "normal" beat analyzer as well.
geposted Thu 13 Jan 22 @ 12:06 pm
