Hi, I need some information.
I have 2 Allen & Heat K2 and I love VDj even though all people have recommended Traktor to me, which I don't like.
I would like to know with Virtual Dj is it possible to use them simultaneously with different commands, in order to have mixing commands such as Cue, Play, Stop, Fader volume EQ on the Xonek2 A and Advanced Loop and FX commands on the XoneK2 B
Unfortunately, few DJs use the K2 with VDJ and before being forced to change software I would like to know if there is a solution with VDJ
Thank you
Thank you
geposted Sat 15 Jan 22 @ 8:54 am
geposted Sat 15 Jan 22 @ 9:08 am
Thanks for your answer, i read the manual, but it doesn't say if it's possible to connect 2 K2 at the same moment with 2 different mapping...Maybe i'm missing some page ?
geposted Sun 16 Jan 22 @ 7:07 pm
yeah you can
geposted Sun 16 Jan 22 @ 7:48 pm
spongebob7 wrote :
it doesn't say
Yes it does, under Advanced Setup.
geposted Sun 16 Jan 22 @ 7:50 pm
groovindj wrote :
[quote=spongebob7]it doesn't say
[/quote]
Right..thanks, i sent you a PM
geposted Wed 19 Jan 22 @ 7:22 am
