Hi,
I've got my MC6000 MK2 out after a bit of a hiatus and found that the left jogwheel operates as expected i.e. anticlockwise = search backwards but the right jogwheel is reversed i.e. anticlockwise = search forwards.
Firmware is up to date v1003.
Has anyone else seen this behaviour and have a fix?
geposted Fri 21 Jan 22 @ 11:46 am
Check the jogwheel mapping to see if it has the "invert" command
geposted Fri 21 Jan 22 @ 12:23 pm
no invert commands in the controller mapping. 100% vanilla reloaded firmware as well.
could I perhaps use script to invert that particular mapping?
deck 2 touchwheel invert
geposted Fri 21 Jan 22 @ 1:17 pm
You could probably remap it, but to be honest it seems like a hardware issue.
If you want to give it a try, use this:
action_deck 2 ? param_invert & touchwheel : touchwheel
geposted Fri 21 Jan 22 @ 5:08 pm
