I was looking through the default mapping for the Pioneer DDJ-SX3 and came upon a parameter I can find no information about. The action assigned to the pitch/tempo slider is as follows : pitch 'dual'
I can find info about all the parameters that can be used after pitch but I can find nothing about dual.
Anyone know why this parameter is used or not used?
Thanks
Thanks
geposted Sat 22 Jan 22 @ 8:00 pm
I asked about this a little time ago it relates to 4 deck control, I'll dig round my pm's see if I can find the message.
geposted Sat 22 Jan 22 @ 9:55 pm
pitch 'dual' will move both pitch sliders of left/right side when used on one deck.
Please notice: It will NOT alter the tempo/pitch of the other deck. It will move only the pitch slider, leaving a "ghost" slider on the other deck.
This action is used only on controllers so that when you switch from deck 1 to deck 3 (or deck 2 to deck 4) and vice versa, VirtualDJ can show you where the physical slider is actually positioned on your controller against the position of the software slider that you have to match before the slider starts working again.
geposted Sun 23 Jan 22 @ 5:06 pm
Thanks all!
Thanks PhantomDeejay! That makes perfect sense.
geposted Tue 25 Jan 22 @ 6:44 pm
