Would it be possible to include/add search by File Name, in the offline sites Tidal and BeatPort Link, from the Main search area?
Currently one can only search for a track by File Name from within a playlist, (of Tidal, or BPL), the search will still be across all files in the service, NOT just searching that playlist one is in.
here are 2 videos . searching for filename: bp12697768 (which is in my VDJ Database) in BeatPort Link search:
1) searching in Main search: (NOT FOUND)
https://gyazo.com/9c965479c190c84ee0df293715e07ba6
2) doing the same search, within a playlist.. (WORKS)
https://gyazo.com/01fddba02e778c1ee94c4841e8f46f40
Identical result with Tidal, when searching for a Tidal track, by file name.
Can one add search by File Name from the main (Root) search areas for Tidal and BPL
PS
the current search fields are set as shown below:
PS
geposted Mon 24 Jan 22 @ 9:44 am
The reason is, I would like to use "Sticky" :
https://www.virtualdj.com/forums/241583/addons/sticky.html?page=1
a plugin created by Locodog, and believe the "Search by File Name" issue, is the cause of offline Sticky-ed tracks NOT showing in the results.
Otherwise I was happy doing a search for FILE NAME, from within a playlist when needed.
Or maybe Locodog can figure some workaround to allow the Sticky to be useful, since it seems that most of the tracks I would like to "Sticky" are the newer tracks that I do not use as much, (and need the reminder) are on BeatPort Link or Tidal.
PS. It does not make a difference if the track that has been added by Sticky is one of the 1000 locally cached tracks, it still does NOT appear when using Sticky, to recall its saved next track pairing (even though the File Name has been recorded/saved to the grouping field in the Tag Editor, correctly).
And if NOT possible, I understand, and fingers crossed, hoping it can can/will be updated to allow the search for File Name.
geposted Tue 25 Jan 22 @ 11:11 pm
