Hi all,
I was wondering if there is any changes i can make in VDJ either via the mapper or the options to disable the waveform display on the RX2.
The issue (its not actually a fault or anything) is that having moved from the original RX, after loading a track the display would reman on the track list view.
Now that i have upgraded to the RX2 and of course waveform is displayed beautifully nce a track is loaded. So the issue is whereas before i could simply use the browse knob to scroll and find a new track without pressing anything, on the RX2 by default you either have to press back or browse on the device for the knob to revert to scroll mode, as otherwise it will just change the zoom of the waveforms instead.
So the ask is simple, is there a way to prevent the waveforms from appearing and instead the display stay in browse mode?
Thanks
Mel
Thanks
Mel
geposted Tue 25 Jan 22 @ 1:15 pm
I think i may have just found the answer myself.
https://virtualdj.com/manuals/hardware/pioneer/xdjrx2/mode.html
As they say always read the manual first!!
geposted Tue 25 Jan 22 @ 1:58 pm
