I have a problem when I search a song in the search bar.The pc is a MacBook Pro 2015 retina with 2tb hard disk.The disk is no set to sleeping.I have tried many builds and the problem is always there.This happens when I start the application almost every time and some times during the program.The speed of the disk is perfect.i have inside 1,3 tb of music. Please help.
geposted Thu 27 Jan 22 @ 7:12 am
Not sure what that could be, but try set VirtualDJ to full disk access in case there are some permission issues. See if that fixes it
https://www.virtualdj.com/wiki/Settings%20not%20saving.html
geposted Thu 27 Jan 22 @ 11:55 am
And if your macOS is very old and outdated, you could also try update macOS
https://www.virtualdj.com/wiki/Minimum%20system%20requirements.html
geposted Thu 27 Jan 22 @ 11:56 am
I have already made does changes . I run high Sierra 10.13.6
geposted Thu 27 Jan 22 @ 3:25 pm
