Hi all,
Since upgrading to the RX2 I was trying to map the custom buttons i had across to it, which for pretty much all of it i have done except for 2, Pitch lock and Pitch Reset.
On my RX i used the master tempo and pitch range buttons while shift is pressed to execute those actions and used to work perfectly, so naturally i have tried to do the same on the RX2.
What i have found when trying to create those actions is that VDJ will not recognise the shift+pitch range or shift+mastertempo button press when trying to learn the key action.
Is this because the RX2 does not support sending those 2 buttons press over midi or is it something i have to change within VDJ itself?
For the moment i have mapped them to a custom pad page and work fine, but ideally i would prefer them as i used to have for ease of access and of course muscle memory of using them that way for years previously.
So any help in whether its a VDJ thing or RX2 issue would be much appreciated.
Thanks Mel
Thanks Mel
geposted Thu 27 Jan 22 @ 10:02 am
I managed to find both the RX and RX2 Midi messages from the Pioneer website and can see that it does indeed not have a +shift midi message available on either of those 2 buttons.
https://www.pioneerdj.com/-/media/pioneerdj/software-info/system/xdj-rx2/xdj-rx2_list_of_midi_message_e3.pdf
Whereas the original RX does have it available
https://www.pioneerdj.com/-/media/pioneerdj/software-info/system/xdj-rx/xdj-rx_list_of_midi_message_e_ver221.pdf
geposted Thu 27 Jan 22 @ 11:01 am
