I have a 32 beat loop using the loop panel active on deck 1. Is there a key bind to stop the loop and keep playing the rest of track and if not what commands would I have to use to make a custom key bind to do this? All the loop commands I saw when I checked were (I think so anyways) for loops on the controller's pads.
Any help would be greatly appreciated! Thanks!
geposted Thu 27 Jan 22 @ 1:00 pm
I figured out a solution. I can add "Manual Loop" to my list of pads and just hit Pad 3 on my controller with manual loop panel selected to create or remove a set loop.
geposted Thu 27 Jan 22 @ 1:50 pm
Not sure what pads you are using, but clicking the 32 beat look again is usually made to exit the loop.
Or you can edit the pads and add loop_exit (or at a custom button)
https://www.virtualdj.com/manuals/virtualdj/editors/padseditor.html
https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/custombuttons.html
geposted Thu 27 Jan 22 @ 2:45 pm
