hi there i need help!
i'm try to achieve the value of brakespeed
for example if i set my brakespeed to 0.25
my idea is get the porcentage (0% to 100%) between (0 to 0.25 )
only whe the brake effect is actived or taping play button to applying the brakespeed
is that posible? do in vdj 2021
thank you in advance
geposted Tue 08 Feb 22 @ 9:00 pm
I have searched all related to brakespeed.
but I din't find anything on vdj script list like.
-->> brakespeed_position
-->> startupspeed_position
will be great if implemented in the near future update
Thank you
Thank you
geposted Wed 09 Feb 22 @ 6:32 pm
I don't quite understand what you're after, but if all you want to do is to have a slider/knob that at minimum position sets brakespeed to 0 and at max position to 0.25 (25%) then all you need to use is this:
param_multiply 0.25 & brakespeed
geposted Wed 09 Feb 22 @ 6:52 pm
PhantomDeeyay!
thanks for your quick response.
What I'm trying to do is get the start speed value from 0 to 0.25.
I am working on my mapper for the HC-4500 controller.
I will like it to be displayed on the screen, gradually increasing the speed of the startup speed build in virtual dj software
I know you are expert on harware divices
jeje! weird why my pic is uploaded upside down!
thanks again. For your help
geposted Wed 09 Feb 22 @ 7:24 pm
"Brakespeed" (as an action) is different than "Brake Start" (as an effect)
So, I'm not quite sure what you're after.
Also, there's no point to have the brakespeed (or the "Length" parameter of BrakeStart effect) to "gradually" change (as in change automatically while in operation)
Finally, besides "brakespeed" there's also "startupspeed"
Perhaps if you explain in more details what you're after, we can provide you more info/help
geposted Wed 09 Feb 22 @ 9:33 pm
OK let me explain a bit better
what I need is to find the position of the startup speed while it is in operation
my idea it displayed on my DN-HC-4500 screen while the startupspeed is in progress
similar how (loop_position) or (sampler_position) work.
but in this case I need for startupspeed.
Thank you
Thank you
geposted Wed 09 Feb 22 @ 10:14 pm
What you want is different than what you say.
You want the "virtual motor" speed, while brakespeed is a constant (as in how much inertia has the "virtual motor")
That's not possible currently
geposted Thu 10 Feb 22 @ 7:29 am
