v8.5-64 b6833 is the Version I have....
And I have lost ALL VIRTUAL FOLDERS AND FILTER FOLDERS.
Umm please help...!! lol..... To many years of info... Gone....
geposted Thu 10 Feb 22 @ 6:07 am
Maybe try to reboot your computer.... to eliminate the possibility that there is a phantom process of VDJ that did not close properly .. during the install .. (can check that using window task manager)
The filters and Folders are stored in your Windows documents, and would not be removed with an update.
geposted Thu 10 Feb 22 @ 9:32 am
I did what you suggested and it looks like it fixed it.. I have to go in and out of everything just to make sure.
geposted Thu 10 Feb 22 @ 6:34 pm
One likely reason might be that you logged into other user account on Windows/Mac.
The filter and virtual folders (for the local drive) is saved in /user/documents/ for the logged in user
geposted Tue 15 Feb 22 @ 12:02 am
