Topic: Virtual DJ jerks and sometimes freezes
Hi everyone, when I use VDJ at high volume and video projection on a big screen, the software stutters and sometimes crashes. I am using a 2017 MacBook Air with i5 and 8GB of RAM. Is it a hardware limitation or do I need to improve the software settings? Thanks for your help
geposted Fri 11 Feb 22 @ 10:19 am
Hello,
i also have problems with my 32gb ram and i7 10750u without an gpu like nvidea,
when i use steam and shaders at same time.
You can set up the video size to minimum in the settings.
Dont use Steam at the same time.
Our u buy a newer PC with a RTX for higher performance.
geposted Fri 11 Feb 22 @ 11:05 am
Thanks! What is the minimum value in the settings?
geposted Fri 11 Feb 22 @ 1:30 pm
