Topic: Create a toggle button
Hello,
I want to create a button that toggles between the following values:
all decks gain "-10" and "0"
deck all set_gain -10 works fine to set the gain of all decks to -10 but i wan't that the same button can be used to go back to 0db also deck all set_gain 0
Need a little help :-)
geposted Wed 16 Feb 22 @ 1:34 pm
geposted Wed 16 Feb 22 @ 1:44 pm
toggle '$GainReduct' & var_equal '$GainReduct' 1 ? deck all set_gain -10 : deck all set_gain +0
geposted Wed 16 Feb 22 @ 1:57 pm
Wow, many thanks for the quick reply! That is what i want and it works fine :-)
geposted Wed 16 Feb 22 @ 2:02 pm
