Topic: Clone deck should kill manual backspin
Just as the program can determine when you are scratching and temporarily disable master tempo..shouldn't it be able to determine when a manual backspin is being performed and therefore stop a backspin if the deck is cloned before the backspin has ended..so as the tracks are correctly cloned together???
geposted Sat 19 Feb 22 @ 3:20 am
