Hello,
I am trying out a controller. Most of it works as expected, but sometimes, there is a slight glitch in the playback. I never had this issue when I was just using my laptop.
Does anyone have the same experience?
geposted Wed 23 Feb 22 @ 1:43 pm
In audio you mean?
Audio drop outs are usually a sign of the audio buffer running dry.
Try set audio buffer (latency) higher.
Either at the driver (if asio), or in VirtualDJ settings (if not asio, under latency)
Try 256, 512 or 1024 samples as latency
geposted Wed 23 Feb 22 @ 2:03 pm
You can also try this tool to see what prevents real-time audio, but having a buffer as mentioned above is all ok ..
https://www.resplendence.com/latencymon
geposted Wed 23 Feb 22 @ 2:04 pm
Thanks a lot! I will try that.
I guess it is related with the audio driver then - because that changed of course since I use the controller.
geposted Wed 23 Feb 22 @ 2:56 pm
yes, the most likely candidate :)
Adjusting the buffer should fix it
geposted Wed 23 Feb 22 @ 10:15 pm
