I have tried so many combination and lots of reading for hours but I can't get it.
Probably so simple for Locodog or Nicotux.
I have been playing with the TEXT plugin.
I made 2 Presets saved as "First" & "Last"
I am trying to add a script in POI to activate one or the other (First or Last).
This script activates whatever the TEXT plugin was left off
deck master video_fx 'text'
or
deck master effect_active "text"
I am trying to select one of the Presets before activating but no luck.
Can't find any example about the "TEXT" plugin.
Thanks for the help.
or
geposted Fri 25 Feb 22 @ 1:52 am
deck master effect_string "text" 3 "YOURPRESET" & deck master effect_active "text"
geposted Fri 25 Feb 22 @ 2:01 am
Thanks Locodog.
I did play around with effect_string but can't figure it out.
what is the # means? Why 3 ?
I tried 1, 2, 4, 5, etc... and I only see the INVISIBLE being check/uncheck.
geposted Fri 25 Feb 22 @ 2:15 am
1 is font, 2 is the actual text, 3 is the preset name. no real reason it's 3 other than that was the 3rd part of the fx that was classed as a effect_string
geposted Fri 25 Feb 22 @ 2:36 am
Thanks again Locodog.
I'm gonna put this script on the sample wiki.
geposted Fri 25 Feb 22 @ 1:01 pm
Been a while since I put an example script in the WIKI and can't see the option to add this example anymore.
Thanks again.
Thanks again.
geposted Fri 25 Feb 22 @ 1:08 pm
"Text Plugin"
1 is font
Note:
You can have up to 360 characters. Anything more, it will not be displayed.
1 is font
Note:
geposted Fri 25 Feb 22 @ 3:30 pm
I'll add it in.
geposted Fri 25 Feb 22 @ 5:16 pm
