Hello wonderful community,
i just got a Korg KP3+ and i was wondering how to connect it if possible,
i may be doing something wrong, as i saw there is a mapper for the KP3 but it doesn't seem to recognize the plus, it there a certain mode i need to be in or something im missing,
thank you in advance.
- VG
- VG
geposted Fri 25 Feb 22 @ 6:19 am
https://youtu.be/rVy2aqQm3U8
in case anyone gets one, and runs into the issue's i did heres the fix.
geposted Thu 03 Mar 22 @ 5:43 pm
in case anyone gets one, and runs into the issue's i did heres the fix for the driver.
EDIT : not sure if an update messed it up i did its no longer seeing it, although i tested and midi does work with other programs.
geposted Sat 20 May 23 @ 6:56 am
A VirtualDJ update or Windows ?
If you think it's VirtualDJ (doubt it) and was working before, you can go back to an older Build and test .. https://www.virtualdj.com/download/build.html
geposted Sat 20 May 23 @ 8:19 am
