My settings:
historyDelay 45
writeHistory yes
But played songs are not marked as played, nor is a history file created. Why?
historyDelay 45
writeHistory yes
geposted Fri 25 Feb 22 @ 3:42 pm
You need to have the fader up far enough so VDJ registers the track as played.
For example if you listen on PFL it will not add to the history.
geposted Fri 25 Feb 22 @ 3:45 pm
Thanks, that was the problem, I only listened through headphones :-)
geposted Fri 25 Feb 22 @ 3:49 pm
