I’ve recently changed to a new laptop (forced due to previous laptop becoming unusable)
A couple of times I’ve noticed that the volume of certain tracks is a lot quieter than others.
Thought “auto gain” may have been the issue but it doesn’t make a difference
Basically, track plays then half way through the volume goes quite low, increase gain to get the volume up then shortly after it returns to normal but the increased gain then means it is far too loud and has to be turned down again
There’s no pattern in what causes it but it’s really annoying. Has anyone had this before and how did you rectify it?
Up to date vdj with subscription. Hoping it’s just a setting that need changing
Thank you
Thank you
geposted Sat 26 Feb 22 @ 12:56 am
