Hi, there are a couple of tracks where I would like to disable video skin at the start via POI then re-enable it at the end due to them having graphics that are covered by the video skin. Is there a command to enable / disable the video skin?
I had a look but couldn't see anything.
Thanks
Thanks
geposted Mon 28 Feb 22 @ 12:10 am
script is
setting 'usevideoskin'
geposted Mon 28 Feb 22 @ 12:23 am
Brilliant. Job done. Thanks!
geposted Mon 28 Feb 22 @ 12:36 am
