Hello peaple! After update to VD DJ 2021 I lost my filter function. I use NUMARK PARTY MIX and I can´t cut any more in between voice (high) and beats (lower). I tried to config by myself but I could´t. Anybody could help me to figurout how do this. Thanks
geposted Fri 04 Mar 22 @ 10:03 pm
Then it was actually the opposite you've lost
Filter is when the filter knob is set to "Filter", and acting as a hi/lo pass filter
But you seem to instead be describing when filter is not in use, because it has instead be set to control "vocal"
That is based on the stems separation feature, so there are at least 2 things to check:
1. That stems separations is actually still configured and running on your setup (is mathEngine enabled, is the separation set up to be automatic, does the stems work when used on the pad page)
2. That the filter knob is set to vocal in the dropdown on the deck(s), like shown below:
geposted Sat 05 Mar 22 @ 8:20 am
