Topic: vdj with ddj sr2
hello
i downloaded the vdj and hooked it up to my sr2, gladly i really loved the vdj and i want to buy the full version, but i have noticed that some of the buttons on the sr2 are not lit, the sync, the play/pause and the cue, so my question is : if i buy the full version will all the buttons on the sr2 be lit or not? thanks
geposted Sun 06 Mar 22 @ 4:57 am
it will be same, when you have the license.
But, assuming you mean you want the sync button to stay lit (and if the mapper is not made that way), its very easy to change in VirtualDJ, at the mapper tab in settings :)
geposted Sun 06 Mar 22 @ 9:54 am
