Hi
I have a problem with the waveforms moving too fast so making it difficult cutting in and out and stuff lots of delay on the cross fader and up faders, my computer is brand new only had it a couple of days as it replaced another new computer which wasn't recognising the ddj400 as a sound device so this is getting really frustrating to have more issues with the new computer, it also does this with rekordbox so is it a computer problem? the computer is this: ASUS - Vivo AiO V241 23.8" All-in-One PC - Intel® Core™ i3, 1 TB HDD & 256 GB SDD, Black & Gold
like i said brand new and surely enough powerful to run vdj or rekordbox smoothly? any ideas? thanks!!
geposted Sun 06 Mar 22 @ 10:40 am
just zoom the the waveform until it has a speed you like.
There is a slider to the far left at the top area waveform for that
geposted Sun 06 Mar 22 @ 11:33 am
as for the DDJ-400 sound devices, make sure its not taken by Windows itself, as its default sound card
(both for playback and record)
https://winaero.com/change-default-audio-device-windows-10/
geposted Sun 06 Mar 22 @ 11:35 am
You can also try set skinFTP in VirtualDJ to 60fps .. or set it to your computer screen fps.
So it appears more "snappy"
I guess you mean the visual feedback is "delayed" cosmetically only
geposted Sun 06 Mar 22 @ 11:38 am
thankyou I will try these and let you know!
geposted Sun 06 Mar 22 @ 3:28 pm
