Hi,
Please, could anyone tell me if VDJ has the feature of Dynamic BPM/Beatgrid like Rekordbox:
https://rekord.cloud/blog/should-you-analyze-your-tracks-with-dynamic-bpm-in-rekordbox
Thanks in advance.
Thanks in advance.
geposted Tue 08 Mar 22 @ 11:10 am
Sounds a lot like variable/multi BPM in VDJ:
geposted Tue 08 Mar 22 @ 11:17 am
Can see more here:
https://www.virtualdj.com/manuals/virtualdj/editors/bpmeditor.html
geposted Tue 08 Mar 22 @ 11:24 am
Ok. Thanks for reply.
Only another question, please:
Can several tracks be selected to do this dynamic analysis process sequentially or does it have to be one by one?
geposted Wed 09 Mar 22 @ 10:54 am
Use a keyboard key or custom button in skin with the action
browsed_file_analyze multi
then select songs you want to analyze for such, with CTRL+A to select all or SHIFT/CTRL to select some
https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/custombuttons.html
geposted Wed 09 Mar 22 @ 11:14 am
Sorry @Rune (DJ-In-Norway)
But i don´t understand how to apply what you mentioned to a batch folder "Re-Analyze (Multiple BPM),
without having to go one by one by pressing the right button, edit bpm and then Re-Analyze (Multiple BPM).
In my opinion, what you indicate can only be applied for a normal BPM analysis.
geposted Thu 10 Mar 22 @ 6:36 pm
