all setting specified 60 fps, in Windows monitor 60 Hz
sometimes the signal wave twitches, fps skin twitching 60-80
changed experimentalSkinEngine - it didn't help
in version x32 - all good
geposted Wed 09 Mar 22 @ 9:25 am
x64 sounds better?
geposted Wed 09 Mar 22 @ 1:20 pm
experimental skin engine set to "no", skinfps set to 60 and it should be ok
geposted Fri 11 Mar 22 @ 1:36 am
DJXHALX
than are you reading?
geposted Fri 11 Mar 22 @ 4:35 am
experimentalskinengine should be yes for best performance. If you get too high readings that might indicate your video drivers are not up to date or not fully directx 11 compatible.
Which gpu do you have?
geposted Fri 11 Mar 22 @ 5:43 am
ADION
why x32 is everything working fine?
geposted Fri 11 Mar 22 @ 8:15 am
The 32-bit version uses DirectX 9, so perhaps the GPU you are using was made before DirectX 11 was available.
geposted Fri 11 Mar 22 @ 8:28 am
ADION
is it possible to run vdj x64 in dx10 compatibility mode ?
and x64 sounds better?
geposted Fri 11 Mar 22 @ 8:58 am
No, and no difference in sound quality
geposted Fri 11 Mar 22 @ 9:30 am
