I have a laptop I7 windows 10 pro with 2 internal hard drives that contain all my songs as mp3 mp4...
can virtual DJ encrypt the songs so that can be played but can't be copied? if not, does anyone know about the software that does it?
N.B. I can't disable the USB and my laptop doesn't have a cd
thx
thx
geposted Thu 10 Mar 22 @ 10:21 am
Windows has a built in feature for that ..
https://www.maketecheasier.com/encrypt-usb-drive-windows/
(although i think it might just be in Windows pro version).
And many 3rd party tools for it as well
geposted Thu 10 Mar 22 @ 11:15 am
so you have win 10 pro and internal hard drives, and you ask:
Can you explain more what you mean by: can't be copied?
You don't want to be able to copy them yourself .. you don't want someone else on a network to copy them? etc ... and there are many more variations possible.
What are you trying to prevent from happening on the internal hard drives of your laptop?
______
Update: Reread what you were asking.. is it that you want to stop someone from using a usb drive from coping your music?
And cannot one either disable or uninstall the USB components from Device Manager. I have not tried this.. its possible that windows will detect them and add them back, wanting to be helpful.
I know when I once worked in a secure environment, and all the usb ports were filled with epoxy.. (not something that can be easily reversed), and you need usb ports to connect your controller(midi devices) to VDJ.
_________________
And if one cannot disable the usb port from Device manager.. the better way (on Win10 pro only) is to use group policy. To disable all external storage devices:
1) Open Run command (Windows logo key + R key) and type gpedit.msc
2) Click on computer configuration > administrative templates > system > removable storage access
3) Double click on All Removable Storage classes: Deny all access and enable it.
Note: If you enable this policy setting no access is allowed to any removable storage class. If you disable or do not configure this policy setting, write and read accesses are allowed to all removable storage classes.
here is screen video of last step in the Group Policy Editor:
https://gyazo.com/77559f8b512a1ca5d31ab1bc066c16e3
______
_________________
geposted Thu 10 Mar 22 @ 12:50 pm
I always say to myself that LOCKS, BOLTS, GATES, FENCE, BANKS etc... or any means of Securing something are only going to keep HONEST People HONEST.
For the THIEF, it does not matter, they will find a way.
geposted Thu 10 Mar 22 @ 2:48 pm
The Magic.DJ, you bring up another great point.. of.... what is stopping someone from taking the entire laptop. (ie taking the entire locked safe)
geposted Thu 10 Mar 22 @ 3:16 pm
I am affraid that someone can copy my internal hard disk but i want him only to play the files but copy them
geposted Thu 10 Mar 22 @ 3:46 pm
well to rip off your files they'd need their own storage, so maybe something like this
https://techjourney.net/how-to-disable-write-access-to-usb-hard-disk-flash-key-drives/
I don't stand by the method used, it's just the first link I found
geposted Thu 10 Mar 22 @ 4:02 pm
At one point in time i used an encryption program on my computer. I had a very long and strong password When I started the laptop i had a 24 digit passcode of numbers and letters to enter. Without that passcode even if someone got to hard drives and tried to copy it the files were locked and encrypted. The only issue i had is it slowed my computer down quite a bit. This was over 10 years ago. With todays faster computers it may work ok for you.... Just dont forgot the passkey!
geposted Thu 10 Mar 22 @ 9:13 pm
