Topic: switch to VDj.
They like more settings and skins.
But they are waiting for a better scratch sound and stability.Then they will immediately throw away Serato and run away to you.
You think to make a VDJ Scratch version? Where will there be more settings for scratch sound, filters, algorithms, etc.
Remove unnecessary functions that add errors in the program code.
More Djs used only jog, sync, loop and cue.
geposted Thu 17 Mar 22 @ 6:13 am
Do you happen to know which controller these dj's are using?
geposted Thu 17 Mar 22 @ 6:34 am
geposted Thu 17 Mar 22 @ 7:26 am
We support over 200 controllers, you are saying that you personally know more than 200 dj's using more than 200 different controllers and they all experience problems with scratching??
geposted Thu 17 Mar 22 @ 7:28 am
ADION
they don 't like the sound of the scratch algorithm itself . Even the move mouse can be heard without a controller. The sound of a "blunt needle"
geposted Thu 17 Mar 22 @ 7:55 am
But which controller do they use? They can't possibly have tried all controllers vdj supports, and the problem in your own topic is likely limited to entry level controllers with low jog wheel resolution
geposted Thu 17 Mar 22 @ 9:28 am
why then choose the scratching sound better in serato, if the controller is the same.
Add more parameters signal for scratch and jog to the settings. Let the user configure it himself.
geposted Thu 17 Mar 22 @ 10:11 am
geposted Thu 17 Mar 22 @ 7:11 pm
IIDEEJAYII
what is not clear?
remove code that is not needed for scratch: stems, karaoke, video, broadcast and etc.
And expand scratch settings. So that the user can adjust the sound of his controller himself.
Make a super flying version. With minimal pc/tablet requirements, with a small delay ms.
It will even be bought by hardware manufacturers and embedded as firmware for hardware.
if you don't invest in scratch, users choose WinAMP for everything else
geposted Fri 18 Mar 22 @ 12:58 am
Winamp that's funny :-)
geposted Fri 18 Mar 22 @ 1:01 am
