Topic: Virtual folders changed
I've been using virtual folders for my singer's songs. I could move them from bottom to top to make the top section my singers for the night. It all worked great until tonight and when I moved a singer's virtual folder from the bottom to the top under the lead singer's folder the folder I moved changed to a sub folder and indented. How do I get them back to being individual folders (no sub folders). I have my house computer using Vdj and it still works the same as before this occurrence. Using windows 10 on both computer and laptop. Vdj 2018 on laptop and vdj 2020 on desktop. I didn't change any settings.
thank you Sharon
geposted Mon 21 Mar 22 @ 7:07 am
It is very easy to move a sub-Virtual Folder, up one level.
See this short video:
https://gyazo.com/aa3cf37c6c87f2c4dba6200700dc1da8
Grab the sub-folder and when dragging up or down, move mouse to left (see the red line with up-arrow) then release folder, to move folder one level up. Mouse movement Right should take allow for folder to become sub-folder, one level down.
Summary: Its all done with the additional LEFT/RIGHT movement when dragging(reordering)
The hard part is moving an upper folder to become a subfolder.. see this thread:
http://www.virtualdj.com/forums/237216/VirtualDJ_Technical_Support/Help__Moving_a_Folder__to_make_it_a_Subfolder_.html?search=virtual%20folder&page=1.45
What you did I have not been able to do. (unless going 2 levels down)
geposted Mon 21 Mar 22 @ 8:09 am
Thank you IIDEEJAYII I can do it yeah!!!!
geposted Mon 21 Mar 22 @ 10:30 am
