Topic: make real folder from a virtual folder
i've tried to do this with programm "track collector" but some folders stay empty after use this programm?? wo can help me? or is there another option o do this?
geposted Mon 21 Mar 22 @ 12:15 pm
What do you exactly want to achieve here?
geposted Mon 21 Mar 22 @ 12:16 pm
CTRL+A in the Virtual Folder to select all the songs within.
Right-click the selection, choose "file operation" .. Copy/move to... and choose a real folder on your drive
geposted Mon 21 Mar 22 @ 12:19 pm
Right-Click the virtual folder and select 'export'
geposted Mon 21 Mar 22 @ 12:20 pm
But as mentioned above. Not entirely sure why you would do that.
Perhaps you mean to export to a usb stick to bring to other computer or instance of VDJ perhaps?
if so, just right click the Virtual Folder and choose Export.. And then choose to export files
hrdnxPRO InfinityMember since 2011
Can we have this option for "Filter Folders " as well???
I tend to use Filter Folders more than Virtual Folders.
geposted Mon 21 Mar 22 @ 2:59 pm
Is it possible in one step to copy also the sub folders? (Not copy every folder seperate)
geposted Thu 24 Mar 22 @ 9:01 pm
