Topic: Denon MCX8000 stuttering
I recently upgraded my windows 11. Denon MCX8000 running on Virtual DJ 2021 stutters for a split second every 1 or 2 songs... it's a half-a-second gap.
Reinstalled the Virtual DJ and the MCX8000 driver twice but no luck...
Could it be the new windows 11?
If not, what would be the suggestion???
Please help.
geposted Tue 22 Mar 22 @ 9:37 pm
Check the Denon ASIO driver is Windows 11 compatible.
Speed Denon do anything at I would severely doubt it.
You should never upgrade an OS without checking everything you use first.
geposted Tue 22 Mar 22 @ 10:14 pm
The commonest cause is ASIO buffer size set too low. What's yours at?
Also you could try using WASAPI instead.
geposted Wed 23 Mar 22 @ 5:50 pm
Upgrade to OS shouldn't make latency worse?
geposted Wed 23 Mar 22 @ 6:01 pm
I use 512 for my latency (default) but I turned the ultra latency option on.
geposted Fri 25 Mar 22 @ 6:20 pm
