Topic: Virtual DJ crashes at Initializing external devices
- I am using Apogee Duer3 and I can’t turn on my Virtual DJ.
- While I connect my soundcard, my Virtual DJ can’t be turned on.
- Can you support me ?
geposted Fri 25 Mar 22 @ 9:02 am
Was that sound card used by VirtualDJ before?
Is it now taken as Windows default sound card? (if so set Windows to use its own card).
And if unsuccessful, try rename settings.xml in /documents/virtualdj/ to a settings_backup.xml
And then start VirtualDJ
(as well as make sure you have latest driver etc to that sound card)
geposted Fri 25 Mar 22 @ 11:54 am
