Topic: bluetooth Sennheiser Headphones
Hi there. I have a pair of bluetooth Sennheiser headphones, when I have set up my apple computer to use virtual Dj, the sound is good but no sooner I add a song from a playlist to be played, all of a sudden my volume on both decks is bought to it's lowest. What am I doing wrong, can this be put right in setting ?. It's really frustrating to say the least.
Kind Regards Paul
geposted Sun 27 Mar 22 @ 1:16 pm
a screen capture of your audio config usually helps in these cases
Did you select what deck to hear in headphones?
Default is automatic, last loaded deck. But you might be listening to master in headphones (headphone mix) or a blend of both (cue deck + master)
Depending on gear and setup
