Hi, I'm trying to map a spare button on my ddi to operate the auto mix feature. I've tried using the button reassign dropper thingy and clicking save but it just won't work. Is this even possible ?? The reason being I DJ at a roller skating rink and quite often have to get down form the DJ booth to sort stuff out on the rink and faffing about with the mouse is not as quick as just pressing a button quickly. Any help would be appreciated, thanks James
geposted Tue 05 Apr 22 @ 1:11 pm
what are you wanting the button to do?
geposted Tue 05 Apr 22 @ 1:20 pm
You mean to enable and disable the automix feature , so that the automix list and automatic mixing "takes over" until you turn it off again?
Yes, the toggle script for that is simply:
automix
automix
geposted Tue 05 Apr 22 @ 1:22 pm
automix
automix
OK thanks, I'll try again to see if I can get hot to work
geposted Tue 05 Apr 22 @ 3:33 pm
