Topic: Seeing up virtual djpro8 with a pioneer ddj sb3
Hi guys I have connected my sb3 to virtual dj and the sound output is missing half the frequency there is no drum beat or voice and it does not change when I set up in the sound settings
geposted Wed 06 Apr 22 @ 6:59 am
Sounds like you have accidentally using the stems feature without knowing
Could also just be filter that is accidentally on
geposted Wed 06 Apr 22 @ 7:48 am
how do i remove the stems ect
geposted Wed 06 Apr 22 @ 9:31 am
Stems? Don't trigger them - or disable them altogether by setting mathEngine to disabled
Filter? Adjust your filter knobs to 12 o'clock
geposted Wed 06 Apr 22 @ 10:14 am
Just to make sure because you are a subscriber:
If you are new to the software or maybe just the latest version of the software, make sure you spend an evening with the manual:
https://www.virtualdj.com/manuals/virtualdj/index.html
And maybe also watch the intro videos on the top pane under settings
geposted Wed 06 Apr 22 @ 10:16 am
