I notice that using a filter button (e.g. Bpm Difference <= 3) with a filter folder that has a sorting order (e.g. sort by key) results in the filter folder's ordering being changed (no obvious meaningful sort).
Example steps:
1) Create a filter folder sorted by key (e.g. In SearchDB = 1 sort by Key)
2) Create a filter button for BPM (Bpm Difference <= 3)
3) Select the filter folder (add the Key column if missing and confirm the list is sorted by the Key column)
4) Enable the filter button and look at the Key column for the filtered results - it seems to have no order anymore
It doesn't seem to happen with a regular playlist that has a column sort order (e.g. the playlist is sorted by key)
Is there a way to fix this or is this a Bug?
Example steps:
geposted Sat 09 Apr 22 @ 1:05 am
Is there any suggestions/update for this?
geposted Sun 17 Apr 22 @ 5:03 am
will be fixed in the next update
geposted Sun 17 Apr 22 @ 8:04 am
Thank you for the update on this. I patiently await the fix.
geposted Thu 21 Apr 22 @ 1:52 am
