I updated today to version 6878 and my Denon Prime 4 kept showing "initializing computer mode". Controls and sound did work, but the screen didn't. Rolling back to version 6839 fixed the problem...
geposted Sat 09 Apr 22 @ 4:59 pm
Any chance you updated VirtualDJ without having Prime connected and later you tried to use it while you were offline ?
Anyways, it's working fine here.
Please try this..
Update to 6878 again.
From Documents/VirtualDJ/Plugins64 folder, delete libusb-1.0.dll and any AKAIREMOTESCREEN64.dll files you have in there.
Restart VirtualDJ , allow a few seconds to download the missing dlls and see if the screen is working again.
Please try this..
geposted Sat 09 Apr 22 @ 9:50 pm
Yes, I did update VDJ without the Denon connected, and I did connect it while offline. I'll try to update is with the Prime 4 connected later again.
geposted Sun 10 Apr 22 @ 10:37 am
