Hi everyone!
This is my first time here and i want to ask you something. I saw virtual dj can live as a broadcast, how to add the "track id" or "Now Playing ID" in your screen? (no, im not thinking about the "UseVideoSkin", because of the virtualdj vinly pics and crossfading). Is there an individual option to show Track ID in the broadcast?
Thanks for help!
Thanks for help!
geposted Sun 10 Apr 22 @ 6:01 am
You can install the Title plugin from Extensions->Effects->Visualisations
But you can also have a look at different video skins (Extensions->Skins->Video Output)
There are many to choose from and not all display the information in the same way.
geposted Sun 10 Apr 22 @ 6:33 am
Thank you so much!
geposted Sun 10 Apr 22 @ 6:46 am
And u know how can i option the new skin? Now i downloaded, what i wanted but i didn't found, how can i edit of this.
geposted Sun 10 Apr 22 @ 7:13 am
Options->Interface will show the available video skins at the bottom
geposted Sun 10 Apr 22 @ 7:46 am
yes i found it, i mean, how can i set the downloaded skin? For example how can i write: My facebook pages, twitter, etc. Because i set the skin, but i can't see any settings inside the skin
geposted Sun 10 Apr 22 @ 7:57 am
geposted Sun 10 Apr 22 @ 7:58 am
@adamferrer88
https://www.virtualdj.com/wiki/BroadcasterGFX.html#socialmedia
@devs scrips used in that link could be made even simpler with
set_var "NAME" "STRING"
geposted Sun 10 Apr 22 @ 1:43 pm
@locodog, indeed, but now that we have set_var_dialog the skin can be updated with a menu too so no script is required at all to update the handles :)
geposted Sun 10 Apr 22 @ 2:19 pm
Will come an update to the skin ;-)
geposted Sun 10 Apr 22 @ 2:29 pm
@rune that was my next thought - vSkin optionsmenu, you got there before I checked.
geposted Sun 10 Apr 22 @ 2:33 pm
