Hi,
I have an odd issue that I can''t seem to make stop happening.
To start I have a new PC
12 Gen 16 Core i9 CPU.
RTX 30 60 Ti FTW3 GPU Driver Version 30.0.15.1215
32GB of RAM
WIN 11 Pro Version 10.0.2200 Build 2200
Mother Board PRIME Z690M-PLUS D4 Driver Version 2145.1.42.0
Using a RANE One
I put two tracks identical to each other and press play. Even with or without SYNC at Play, or auto Sync the same thing happens.
The top track will start moving a little faster and keep doing this all the way through.
Here is what is happening while this goes on:
Both BPM's remain exactly the same.
Pitch stays the same.
Key remains the same.
The audio sounds the same except one track is not aligned with the bottom one. But sounds the same speed on both tracks. On is not faster sounding or slower sounding. I am not sure how to put it.
The top track slowly move ahead of the bottom one... Very annoying.
On my Rane One both pitch controllers are centered.
This also happens on different tracks.
I can run in Serato and things remain perfectly in sync.
Again, to be clear it doesn't matter if I have auto sync on or off. Doesn't matter if sync on play is on or off. Doesn't matter if pitch or key are different. All options off or on make no difference.
I am using the same track on both slots, and it can be any track it does the same thing.
I have the latest drivers for my GPU and CPU, as well as the latest VDJ v8.5-64 b6886
In Serato this is not an issue. Serato DJ Pro 2.5.11
I bet this is a simple fix and I just cant figure it out.
Any help would be awesome.
32GB of RAM
Using a RANE One
geposted Mon 11 Apr 22 @ 8:46 pm
I am having this problem, sadly I see this post was made in April and nobody has commented... Please let me know what you did to correct the situation.
geposted Mon 03 Oct 22 @ 7:10 pm
